Blaster Suspension
Old Jul 15, 2005 | 07:12 AM
BlasterDunatic's Avatar
Default Blaster Suspension
I own an '05 Blaster (see mods in sig.) and when i'm riding it, i absolutlely can't stand how hard the suspension is on it. I know you can put warrior or banshee front shocks and a 250r rear shock on it, but i want to know if you can adjust the stock shocks to make them looser/tighter. Also if anyone has made their's looser, how does it perform going over whoops and jumping it, as compared to stock.
Thanks for any help.
Old Jul 15, 2005 | 09:37 AM
Warrior02man's Avatar
stock warrior shocks suck. Ive heard about the banshee shocks.. and heard that they suck. No idea about the 250r though.. just get a works suspension setup.
Old Jul 15, 2005 | 12:09 PM
Storj's Avatar
if your jumping your going to want it a little stiffer unless you weigh about 90lbs, and there is a bolt on the rear shock you can loosen just look at the bottom and you will see. With the front shocks i believe they have diffrent spring settings that you can change
Old Jul 15, 2005 | 07:20 PM
Ok, i saw the rear shock and how to adjust it, but has anyone tried cutting the front springs? I know it sounds crazy but i'de rather do that then spend the 2k for new shocks.
Old Jul 15, 2005 | 08:57 PM
Banshee392's Avatar
Just buy some works dual rate steelers from rockymountainatv, $324 before shipping. As for the rear, a 1987 250R rear shock would work PERFECT, you will just have to buy a 14mm bolt close as the same width as your swingarm mount and drill the swingarm hole to 14mm, then it will bolt right up!
Old Jul 17, 2005 | 03:53 PM
Storj's Avatar
Are you serious about cutting the suspension? That would really mess it up. How much do you weigh because the suspension on a blaster is pretty loose even when its almost at its highest settings.
Robinhood
Dec 26, 2015 10:28 AM
Ahtatu
Sep 28, 2015 12:14 PM
bigred20653
Sep 19, 2015 02:11 PM
nastyblaster100
Sep 13, 2015 01:19 PM
chewy78
Sep 8, 2015 10:37 AM
