Keeps destroying belts....
Old Jul 16, 2005 | 07:19 PM
TrailBlazerguy250's Avatar
Default Keeps destroying belts....
My sportsman has destroyed 2 belts , one a new dayco and a polaris one , I think the clutches might need to be realined , what yall think ?
Old Jul 16, 2005 | 08:44 PM
SPORTSMAN70003's Avatar
How is it destroying them? Is it shredding them or putting burnt spots on it.
Old Jul 16, 2005 | 11:12 PM
ftwflh's Avatar
Check your vent tubes for restrictions such as mouse nests.
Old Jul 17, 2005 | 12:05 AM
they have burn marks and its making the strands come off . i checked and no nests but thanks !
Old Jul 17, 2005 | 02:38 AM
scramblerXrated's Avatar
yes clutch alignment is definitely in order.
if it happend all of a sudden, you might check your clutch components,(clutch buttons and helix) to make sure of proper function, and check your motor or tranny mounts. if the motor or tranny are shifting under load, this will cause misalignment too.
X
Old Jul 17, 2005 | 02:53 AM
thanks , i will deffintaly get them alined and check all the mounts !
Old Jul 17, 2005 | 01:19 PM
ScramaDamaDingDong's Avatar
your belt might be too tight, you may need to add a shim to the driven clutch to loosen things up a little. check your belt defflection.
Old Jul 17, 2005 | 03:24 PM
Yeah that sounds like a good idea to because its been happening ever since the belt would not disengauge , I could come to a stop and it would start to take off again , so I pulled the belt after it fliped over and put a new one on and a new belt houseing and seem to have destroyed both again ! SO ill definitly check that to , thank yo8u all for the help , TBGUY250
1000gade
Sep 9, 2015 04:41 PM
Elkaholic
Sep 6, 2015 02:44 PM
Nondem
Where to Ride
Jul 23, 2015 07:38 PM
dirt817
Apr 13, 2001 02:32 PM
