never mind.
Old Jul 17, 2005 | 03:00 PM
hardwood700's Avatar
Default something locked up sportsman90
Old Jul 17, 2005 | 03:06 PM
spike99's Avatar
Remove the spark plug and try turning over "very slowly" with the kick starter. If that won't work, try to turn the flywheel starter gear with a screw driver. Don't try too hard. Just want to determine if the kick starter gears are stuck or if your air filter allowed some water into the engine (Piston area). If you hit water and it died in the middle or immediately coming out of the puddle, you probably have water in the piston - sucked in through the air filter.
Hope these ideas helps...
Old Jul 17, 2005 | 05:59 PM
Default never mind.
thanks for the reply spike99.i took my post off because i scrolled down the list of posts and saw someone else had that problem and did't want to repeat it.
thanks
Old Jul 17, 2005 | 07:16 PM
wrh16's Avatar
Default never mind.
If you kick it too hard with water in it, it can push the reeds backwards thru the cage. Oooops!
Designstudent
Mar 20, 2003 10:33 PM
Designstudent
Utility ATVs
14
Mar 16, 2003 12:39 PM
hawkeyecp
Jan 23, 2003 12:37 AM
gaff
Jan 15, 2003 08:04 AM
