How to adjust air/gas on carb???
Old Jul 19, 2005 | 10:33 PM
polarbare21's Avatar
Default How to adjust air/gas on carb???
We have a new/used 96 425 Magnum, it seems to be running rich, but I cannot figure any way to get a screwdriver on the screw to adjust it.
I think the screw is on the bottom front of the carb, but there is only about an inch of clearance.
Any help guys??
Thanks
Old Jul 20, 2005 | 03:04 AM
jimmypsp700's Avatar
Use a stubby or a drill flat head bit.
The air screw only effects idle and the first 1/8 throttle.
Jim
Old Jul 20, 2005 | 10:17 AM
A stubby wont fit in there, I'll try to grind one shorter and more narrow.
I get some black smoke, black fouling on the plug, a slight hesitation, and miss at low rpms.
thanks
Old Jul 20, 2005 | 11:17 AM
ATVnRocks's Avatar
Sounds more like needle & seat probs than a idle mixture setting, just a thought.
Old Jul 20, 2005 | 04:22 PM
Kerbbirds's Avatar
Take the top off the carb, don't mess up the rubber diaphram pull the slide out , dump the needle out in your hand there shoul be a white plastic spacer on top of the needle dont lose it. Lower the little clip on the needle one notch, this will lean it out.
Old Jul 21, 2005 | 08:30 AM
Ah hah........ thanks!
Cole Hadden
Jun 15, 2025 09:05 AM
Firefighter400
Oct 8, 2022 06:38 PM
GregM
Mar 6, 2018 06:53 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
