Top end advice
Old Jul 21, 2005 | 02:54 PM
BUBFRider's Avatar
Default Top end advice
I've started blowing smoke on decel. After some advice from others, I chacked the breather and it seems clear. Last weekend I replaced the plugs (very wet and black). After only a 5 min. ride, the new plugs look the same.
Where should I start? And the big question....how much is it going to cost me?
Old Jul 21, 2005 | 04:08 PM
Oldmanracing's Avatar
On decel it is usually a carburetor problem.
Float too high or needle too high or too big of an main jet.
You need to review and let us know what is your carb basics set at.
Old Jul 21, 2005 | 04:26 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
If its a thumper it could be bad valve stem seals.
Old Jul 21, 2005 | 04:38 PM
BUBFRider's Avatar
It looks and smells like oil smoke as opposed to rich mix smoke.
Old Jul 21, 2005 | 04:56 PM
KTM Patrol
Former Chinese POW!
So its a 2 stroke?
Old Jul 22, 2005 | 08:55 AM
BUBFRider's Avatar
???? No. it's the 650.
I was having problems with the jetting and it smoked until I backed the air screw out. By mix, I mean air/fuel mix.
Old Jul 22, 2005 | 07:16 PM
jackass650's Avatar
I'm not sure but wouldnt backing out the screw richen the mixture seeing as how the screw if after the carb? if it was on the other side of the carb (intake side) backing out the screw would lean the mixture out, maybe I have dont know what I am talking about, just my .02, how many turns you have the screw from the lightly seated position? mine is like 3 turns out and runs awesome
ultangler
Nov 30, 2024 01:35 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
kodiacrunner
Oct 4, 2015 11:52 AM
wrencher82
Sep 28, 2015 10:02 PM
