TB 250 Sitting around and having problems
Old Jul 23, 2005 | 04:39 AM
Motoxxxracer096's Avatar
Default TB 250 Sitting around and having problems
Well, i have a trailblazer 250, it's been sitting not started for about a year. Well, i bought a new plug, drained the gas, fuel filter is clean, drained the carb. Finally got it started, sounds great, but when i go to rev it it just bogs out and will eventually shut off,only thing i can think of is maybe the jets need to be cleaned, idk tho, any help?
Old Jul 23, 2005 | 10:25 AM
Raziel's Avatar
Hey just sounds to me that your carburetor has gotten some dirt or varnish in it since when you give it throttle, the volume of air is increased but the fuel either from the bowl/float or the main fuel jet is being restricted. If you have an air compressor, just remove the carburetor and disassemble (do on a clean table with a light colored rag ) and clean the jets and bowl valve. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jul 23, 2005 | 08:44 PM
Budman650's Avatar
I've had 6 TB's and they all have carb problems from sitting. I've tried all the stabil adds and nothing works, especially out in this heat. If I know I won't be running, I drain the carb and gas tank. The main jets are always plugged or restricted.
Old Jul 25, 2005 | 11:00 AM
Speedwerx's Avatar
I'd suggest check needle and seat pressure once you have everything cleaned as well, if the quad sat that long in that heat you will probably need to put a new needle and seat in it.
Firefighter400
Oct 8, 2022 06:38 PM
greg74
Sep 10, 2019 03:03 PM
Captjay
Jul 23, 2015 12:33 PM
steveo612
Jul 11, 2015 08:35 AM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
