400EX rear axle bearings
Old Jul 24, 2005 | 06:42 AM
five20too's Avatar
Default 400EX rear axle bearings
My friend has an '01 400EX and he wants to change his rear axle bearings out but he can't get his axle to come off. He's not sure which way to slide it or how to get the nut all the way out if he even needs to. If you guys know, please feed back with detailed instructions because he needs to get it going. Thanks for the help guys.
Old Jul 24, 2005 | 09:04 AM
quad2xtreme's Avatar
do a search. It has been posted many times.
Axle comes out to the left side of the quad. There is a c-clip underneath the large bellshaped nut. You have to loosen the lock nut and the bell nut far enough to get to this c-clip.
Don't remove the brake setup until you get this far. It helps to have someone else step on the brake petal while loosening these nuts.
Good Luck.
Old Jul 24, 2005 | 09:08 AM
TheTurtle's Avatar
this is a step by step with picture rear axle change which should get you through the project. click here
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Aug 5, 2015 05:55 PM
Peter_
Jul 18, 2015 07:06 AM
Rider252
Jul 6, 2015 03:37 PM
