Polaris Died!
Old Jul 26, 2005 | 01:12 AM
Rjganser's Avatar
Default Polaris Died!
I was pulling my cj-5 up the driveway, everything was fine, parked the machine, hopped on it later to to ride it, fired up and died like it was out of gas. So i filled it up and still nothing, wouldnt fire or anything, shot ether into intake just to see if it would fire, nothing. So i pulled the plug, and checked for spark, with the old plug and a new one, It sparks for a second right away, and then nothing! So i let it sit for a week, went out to fire it up, it idles but thats it, if you touch the gas it dies. Any ideas on where i should start? I am thinking really weak spark, I did have water in my recoil cover, so i drained that. I am new to the small engine thing. Do i just pull the recoil cover to get at the ignition components? I am thinking they may be dirty from the water that was in there, as it looked like rusty water.
Thank you.
Ryan
Old Jul 27, 2005 | 01:15 AM
Rjganser's Avatar
I pulled the cover, and the flywheel is really rusty, I have not been able to pull the flywheel itself yet though. Will rust on the flywheel and magnets cause what i described? also, how do i actually test if my throttle safety is what is causing my no spark situation?
Ryan
Old Jul 27, 2005 | 12:06 PM
Kerbbirds's Avatar
clean the flywheel with emery paper. Take the top off of the throttle box above the thumb throttle and adjust the slack so that there is just a little slack in the cable.
Old Jul 28, 2005 | 01:29 AM
Rjganser's Avatar
I just did both of those things about an hour ago, still no spark. I just adjusted the throttle until the lever had about 2mm of slack. Does anyone have access to a repair or FSM for this model or similar 425 that could tell me what to check for? I am looking to test the coil, stator, and whatever other iginition items that i can. I have to order a repair manual and that will take almost two weeks.
Ryan
KimSJoh
14
Jul 18, 2015 07:20 PM
Reactant
Jul 16, 2015 10:29 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
