04 sportsman 400 electrical problem
Old Jul 26, 2005 | 11:55 AM
sportsmanman1's Avatar
Default 04 sportsman 400 electrical problem
Hey guys whats up? I ran into an electrical problem and hope someone can help me out. I have a 2004 sptsman 400 the other day I was out riding through some water nothing deep but I was moving pretty good and water was going everywhere. About a half an hour after I was finished with the creek I was just doing some light trail riding and the bike just shut off. When you had the key in the run position the LED display does not work the lights do not work and it will not crank. I jumped the solenoid wires to see if maybe the starter wires or something and the bike cranked over just fine but it won't run because I have no power to the display panel ???????????? any suggestions?[img]i/expressions/face-icon-small-confused.gif[/img]
Old Jul 26, 2005 | 02:04 PM
99farmboy's Avatar
I'd suggest you start by following wires looking if a connection came apart. Use a multi meter or something to see if you have power to the key.
Old Jul 26, 2005 | 02:59 PM
Kushman's Avatar
Thats not a known problem, as farmboy stated, your're gonna have to start at one point and eliminate things as you go
Old Jul 26, 2005 | 03:02 PM
ATVnRocks's Avatar
Not a known prob????
See if I'm right here, there is a fuse link in the main harness on the inside frame near the battery, lightly tug on the wires here, u should find one corroded, or it might just have a breaker that won't reset.
Old Jul 26, 2005 | 08:48 PM
Kushman's Avatar
Known problem as in widespread. I'm sure it has been a problem for some, but its not a widespread problem. And it is one of the first places to look as Rocky said
Old Jul 26, 2005 | 09:11 PM
Backinthesaddleagain's Avatar
Another place to check is your sparkplug wire. Polaris had a recall on these machines because the sparkplug wire was pinched between the gas tank and a metal component ( brake hydraulics distributor block if I remember right ) on MANY that were built. It eventually wears away the wire and it shorts out. You then need to get a new wire/coil assembly installed. It's a factory recall item and will be done by the dealer free of charge. I know because mine died this way with only about 25 hours on it. If you haven't already.....check it out. Follow the sparkplug wire by hand up behind the gas tank and feel if it's being pinched/jambed between the two. It's difficult to see.
I'm not saying that this is your problem........but if you didn't already know about it then you should definately check it out.
Old Jul 26, 2005 | 11:39 PM
Thanks for the suggestions I will give them a try tomorrow after the rain lets up,,,,,,,,,,,,I'll let all of you know what the problem was when I find it.
ripperray
Oct 10, 2023 02:42 AM
skittero
35
Mar 1, 2019 12:39 AM
Raccar1
Jun 18, 2015 02:17 AM
DOAinNY
Jun 11, 2015 10:34 PM
