250 tb sprockets?
Old Jul 26, 2005 | 08:46 PM
bcmudbogger's Avatar
Default 250 tb sprockets?
witch sprocket would i change to affect the top speed of the tb with keeping almost all the bottom end? the front drive sprocket or the sprocket on the back axel?
Old Jul 27, 2005 | 10:42 AM
Speedwerx's Avatar
If you want more top speed out of your t/b you are going to have to loose a little bit of bottom end, you can either go bigger on the front or smaller on the rear for more top speed changing on toothe onthe front is like changing 2-3 teeth in the rear. Your quad should come stock with 11 front / 36 rear with a 76 pitch chain.
Old Jul 27, 2005 | 12:56 PM
k ill try playing with the front drive sprocket. i have alot of bottem end enyways so theres no problems there
buddieboy
Dec 9, 2016 05:50 PM
merryman
Sep 19, 2015 03:15 AM
Canamaniac!
Sep 15, 2015 06:19 PM
Old Deer Hunter
Sep 2, 2015 01:39 AM
Dammar
Aug 26, 2015 07:12 PM
