250 tb sprockets?
If you want more top speed out of your t/b you are going to have to loose a little bit of bottom end, you can either go bigger on the front or smaller on the rear for more top speed changing on toothe onthe front is like changing 2-3 teeth in the rear. Your quad should come stock with 11 front / 36 rear with a 76 pitch chain.
