K & N airfilters, anyone use them?
Old Oct 17, 2000 | 07:18 AM
WEETOOTS's Avatar
Has anyone used the K&N airfilter with their SP500HO or used the stage 1 jet kit? Is it worth it?
Al
Old Oct 17, 2000 | 11:06 AM
Farmr123's Avatar
I tried one out in my Xplorer 400 for a while. It gained a couple of top speed MPH and seemed to run just a hair cleaner, especially at higher speed. The filter medium looked thin to me, but the oil is supposed to catch all the dust. I personally run a Uni. I don't know whether the K&N filters well enough, but I know the Uni does.
Farmr
Old Oct 17, 2000 | 11:29 AM
Bill.Ciliberti's Avatar
I run the KN in my OO Xplorer 400cc,and I do keep a good watch on it.Im just not certain that it filters out the finer particles of dirt/dust.They [KN] says that it's the best around,but im still cautious.
I know for sure that the carb takes in more air with it,I can actually hear it breathing in more air on acceleration.Performance?I really dont know.===Bill
Old Oct 17, 2000 | 11:45 AM
Xplor's Avatar
If your riding in dusty conditions...get a UNI filter. It stops much more dust particles than a K&N from what I have heard. Plus it breathes a lot better than stock.(I run one on my Scrambler)
Old Oct 17, 2000 | 12:19 PM
TEXMud's Avatar
If you are using a K&N you should also be using an outerwear filter.
Old Oct 17, 2000 | 02:40 PM
Farmr123's Avatar
An old mechanic friend of mine told me a trick to see how well your air filter is working. Put a little dab of grease on your finger, then smear some in the intake tract past the filter. You don't need hardly any, just enough to leave a little residue. The grease should NEVER get any dust stuck to it. Any dust you see will be a small percentage of what actually went through the engine. I tried this when I got my Uni & is still clean, but have only about 100 miles so far. An outerwear is supposed to help the K&N in heavy dust, as well as keep water out of the engine, though I never tried one.
Old Oct 18, 2000 | 01:49 AM
Thor's Avatar
What you said is very true, there should be no dust on the circumference of the intake venturi. Unfortunately there was when I used a K&N under very dusty conditions doing what was prescribed in their operating/maintenance instructions.
Racing in the dunes or low dust conditions were no problem but when running in the dust of iron ore aggregate roads and trails the K&N is not as effective as the UNI. IMHO
Old Oct 18, 2000 | 01:57 AM
WEETOOTS's Avatar
Thanks to all who have replied. I have seen the light, UNI is the way to go - dustless. I also liked the idea of putting just a litlle smear of grease in the intake, to see how much dust/dirt is getting through.
Al
Old Dec 7, 2000 | 11:46 PM
waynaferd's Avatar
here it is
RotGutBottom
Apr 16, 2001 12:43 PM
dataspng
Apr 1, 2001 03:24 AM
PaulC
Feb 26, 2001 02:30 PM
TexasWarrior
Aug 3, 2000 04:05 PM
MojaveManiac
Jun 14, 2000 11:42 PM
