Another scrammy issue
Old Aug 3, 2005 | 01:25 AM
Bretman's Avatar
Default Another scrammy issue
Can somone please tell me if they can view my oics and my bio. I got them posted, i no it. If not how do i fix this. Also, i notice that when i ride real slow i hear ths little tick sound or somthing, it sounds like its comming from the back, i greased her up and the chane isnt loose, i dont no what it is. I am realy low on oil i noticed, could it have somthing to do with that. Any tips would be appreciated.
Old Aug 3, 2005 | 01:48 AM
axelmain31's Avatar
yes i can see your pics, sorry thats the only thing i can help you on
Old Aug 3, 2005 | 02:02 AM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
could be a few things
-kink in chain runs over swingarm and makes a little knock/tap sound as it hits swingarm (which would be consistently just about every revolution of the chain)
-axle bearing are bad and making a random popping/crunching noise
-swingarm bushing where it mounts to frame could be bad causing a clunk on downhill bumps
maybe some more details...
Old Aug 3, 2005 | 02:14 AM
jimmypsp700's Avatar
If the chain is on the loose side it could be slapping the wear pad on the top of the swingarm.
Jim
Old Aug 3, 2005 | 11:42 AM
Bretman's Avatar
I am almost positive it isnt the chain but i will lube that to see of it makes a difference. I want to say that it sounds like the axle berring is bad. That fits the story best right now, How much are new berrings, is it a hard fix to do your self. If its not that then what else could it be?
Old Aug 3, 2005 | 12:38 PM
Bing's Avatar
Super Quad Patrol
if it is the chain,,,,lube won't help much
jack up the back end of the quad and rotate the tires,,,,and see how close the chain comes to the swingarm
Old Aug 3, 2005 | 04:16 PM
Bretman's Avatar
what will that do though, when you sit on it the chain tightens up anyways because you make the swing are flex up and down. I think its the berrings, it like a little click or a tick sound i here when i give it gas and move alittle bit. How hard is it to replace the berrings. how much are new berrings.
Old Aug 3, 2005 | 05:57 PM
scramblerXrated's Avatar
it sounds like you have some broken rollers on the chain. OR your front sprocket could be missing a tooth or two. it wouldnt hurt to remove the chain and give it a good look see on both sides. and also lookat the sprocket condition.
i just went thru this same exact thing a few months ago.
good luck!!!
X
Old Aug 3, 2005 | 06:00 PM
Bretman's Avatar
thanks scramblerxrated, i swear thats about the best info i got all day.
Old Aug 3, 2005 | 06:25 PM
rieds's Avatar
if it's not your drive sprockets or chain lay your leg against the clutch cover and see if you can feel it there. that's what my tranny chain sounded like when it first started gettin loose before it started to actually jump the sprocket.
