2000 Scrammy 500 4x4 burnin through LOTS 'O' gas
Old Aug 3, 2005 | 02:35 PM
DJN's Avatar
DJN
Default 2000 Scrammy 500 4x4 burnin through LOTS 'O' gas
totally stock but sucking gas like a motha. I'm running pretty rich...anything I can do to lean it out? Not sure if there are any adjustments before rejetting it. I haven't pulled the carb so I don't know if you can adjust the needle postition or anything so I thought I would ask if anyone tweaked there's a little bit with a similar problem. If I rejet what could I put in with a stock setup?
It's getting about 40-45 miles per tank maybe...[img]i/expressions/face-icon-small-disgusted.gif[/img]
as always, thanks for any help
Old Aug 3, 2005 | 02:42 PM
garrett5462's Avatar
my scrammy gets aroung 40 to. i will go out on a 35-45 mile trail ride, about 3 to 4 hours and i will be about out of gas and can see the bottom of my tank. is your quad running right, or does it just have bad mpg?
Old Aug 3, 2005 | 03:49 PM
DJN's Avatar
DJN
Actually it runs really good...I think it's just bad MPG. There's got to be some adjustment to lean it a little
Old Aug 3, 2005 | 07:52 PM
ftwflh's Avatar
sounds about right on gas wait until you mod it up[img]i/expressions/face-icon-small-smile.gif[/img]
Old Aug 3, 2005 | 09:40 PM
XtremeSkier's Avatar
yep! thats how it goes
my quad was terrible b4 i put just the pipe on!
i was sucking a full tank in about an hour and a half of fast riding[img]i/expressions/face-icon-small-shocked.gif[/img]
now i can go 3 hours easy..its wierd how it changed so much...i think i just wanted to go real fast when i first got it to[img]i/expressions/face-icon-small-wink.gif[/img] it was alittle bit faster then my magnum 325
Old Aug 3, 2005 | 10:19 PM
big engine, big carb, need lots of gas to feed em'.
mywifesquad
8
Sep 21, 2015 08:20 AM
toonces
Sep 5, 2015 01:14 PM
Pahuntman
Sep 5, 2015 11:07 AM
Dan Newberry
Aug 30, 2015 09:42 AM
