Need Tips For Jumps
I just started going off jumps with my Yamaha Warrior, and I need some tips on how to do it properly.
<u>Aftermarket mods on my quad</u>
-Cobra Exhaust(Stock Header)
-DG Front Bumper+Back
-Bigger Back Sprocket
P.S and if anyone knows any parts I should buy for my Warrior leave one.
Lean to carry your speed to a jump. This will keep you level if you are full on the gas at take off tends to throw your nose high. If your nose is high learn to tap the rear brake. If your coming in nose low pin the throttle.
repitition
do the same jump over and over and over
when it gets boring pull the clutch in and let it out just before landing
when thats easy jump pull clutch and tap brakes
when you have that jump, pull clutch, tap brake and land on the gas
baby steps man baby steps
let me tell ya...a 50ft jump isn't much harder than a 20foot jump, but the ground is when you land...so start small and work up
