Need Tips For Jumps
Old Aug 3, 2005 | 04:22 PM
Warrior13's Avatar
Default Need Tips For Jumps
I just started going off jumps with my Yamaha Warrior, and I need some tips on how to do it properly.
<u>Aftermarket mods on my quad</u>
-Cobra Exhaust(Stock Header)
-DG Front Bumper+Back
-Bigger Back Sprocket
P.S and if anyone knows any parts I should buy for my Warrior leave one.
Old Aug 3, 2005 | 04:29 PM
rooster123's Avatar
Lean to carry your speed to a jump. This will keep you level if you are full on the gas at take off tends to throw your nose high. If your nose is high learn to tap the rear brake. If your coming in nose low pin the throttle.
Old Aug 3, 2005 | 09:09 PM
RacinJason's Avatar
repitition
do the same jump over and over and over
when it gets boring pull the clutch in and let it out just before landing
when thats easy jump pull clutch and tap brakes
when you have that jump, pull clutch, tap brake and land on the gas
baby steps man baby steps
let me tell ya...a 50ft jump isn't much harder than a 20foot jump, but the ground is when you land...so start small and work up
Old Aug 5, 2005 | 06:22 PM
CHECKSIXS's Avatar
Racinjason's got it right[img]i/expressions/face-icon-small-smile.gif[/img]
Just make sure you keep on the gas when your back wheels launch or you could be sucking dirt.......esp. on a steep jump.
exmotocrosser
Sep 26, 2015 08:18 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
black_thunder
Sep 22, 2015 07:59 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
