400 ex problems
Old Aug 3, 2005 | 05:35 PM
GOHARD's Avatar
Default 400 ex problems
Its a 03 and theres no juice going to the key.Checked everything and did what the dealer said to check and still nothing.Checked the fuse and all the connections and nothing.battery has good charge to.Any help
Thanks
Old Aug 3, 2005 | 05:39 PM
RacinJason's Avatar
Look for any obvious problems in the wire loom, such as burnt frayed wires
make sure the terminal connections are good
also check to make sure the bat cables themselves are not pulling apart...I broke two grnd cables before I made my own
Old Aug 3, 2005 | 09:19 PM
TractorPacker's Avatar
Do you have a balloon?
Get a test lite, and put the ground on the negative on the battery. Start at the closest connection to the battery and go up to the key. If the tester works, up to a point that will help locate the problem.
Old Aug 4, 2005 | 01:06 PM
Hondanutcase's Avatar
I know you said that you checked the fuse. Change it anyway. Sometimes you may not be able to see if the fuse is bad. They are cheap and it can't hurt. Clean you battery connections also.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
