NITROS
Old Oct 17, 2000 | 07:25 PM
speedy2's Avatar
What would it take to run nitros in my warrior?
thanks for the help
Old Oct 17, 2000 | 09:20 PM
400exalltheway's Avatar
no effence, but why would you want to, the only quads i've ever seen that ran nitros where 250r's and banshee's. you could call trinity racing and ask them. i know they do nitros kits, but their exspensive
Old Oct 18, 2000 | 08:40 AM
ATVPRO's Avatar
you could easily put a nitrous kit on you just have to buy one. It will consist of a nitrous solenoid and bottle, you have to wire up a switch to control when you want it on, (only at full throttle is the safest) and you will need to rejet your carbs main jet alot richer or you'll have a major meltdown
Old Oct 18, 2000 | 01:11 PM
brandon's Avatar
Four strokes resond better to NO2 than two strokes do. I've yet too see a two stroke run better on NO2 than with just plain old alcohol. The four strokes however respond rather well provided it is set up correctly. I would completely build the engine first though. You need to have the engine ready for the NO2. Pipe, valves, cams, piston, head ported, crank work,etc should all be done first. You will see more effect on a built motor than a stock one. Trintiy does aoffer a kit, but I would find a local car guy who can help you tune it in and set it up. I usually do not recommned this, but in this case I do. I've only seen the car guys get it right.
Old Oct 18, 2000 | 03:37 PM
speedy2's Avatar
Thanks for all the info. im 14 so i don't thank ill be doing this any time soon. But im glad to know i am able to do this to my quad thanks .
Old Oct 22, 2000 | 09:43 PM
tomtcat's Avatar
Install a kit. I run it on my 1000 Thunercat.
I know a guy that runs it on his 250 r for winter ice drags and basically that or hill climbing is the main purpose.
You need to have a good 12volt source, wire in an xtra fuel pump, run a 2# bottle about 60 seconds of continuous button use, which is a lot! Keep the bottle at 80 degrees for around 950#'s of pressure. A single cyl will be much easier than my triple cyl snowmo. Install time probly 3 hours. Don't let people BS ya the stuff works and if you don't run HUGE NOS jets you will be just fine for reliability. A bottle refil is like 7 bucks if I remember from last year.
It's fun stuff. However it is dangerous stuff too! All kinds of bad things can happen. (push button while idling? BOOM) et. Just need common sense... come to think of it strike that last line! LOL.
Go to NOS's website they have much more info for ya there.
You can also try www.magnumforceracing.com they have kits too.
Old Oct 25, 2000 | 11:51 PM
speedy2's Avatar
i live in bumpass, virginia,so were could i get some nitros
Old Oct 28, 2000 | 11:03 PM
Recondude's Avatar
Team Alba Racing has kits for Warriors. 600 bucks for 40 % more power it says. They have a bunch of stuff for warriors. Goto www.albaaction.com and youll find all your needs
RacewayATV
May 30, 2006 10:50 PM
mean650
Nov 19, 2004 09:10 PM
Lyrch
Mar 17, 2004 12:48 PM
SLIM660
Apr 23, 2003 12:48 AM
