NITROS
you could easily put a nitrous kit on you just have to buy one. It will consist of a nitrous solenoid and bottle, you have to wire up a switch to control when you want it on, (only at full throttle is the safest) and you will need to rejet your carbs main jet alot richer or you'll have a major meltdown
Four strokes resond better to NO2 than two strokes do. I've yet too see a two stroke run better on NO2 than with just plain old alcohol. The four strokes however respond rather well provided it is set up correctly. I would completely build the engine first though. You need to have the engine ready for the NO2. Pipe, valves, cams, piston, head ported, crank work,etc should all be done first. You will see more effect on a built motor than a stock one. Trintiy does aoffer a kit, but I would find a local car guy who can help you tune it in and set it up. I usually do not recommned this, but in this case I do. I've only seen the car guys get it right.
Install a kit. I run it on my 1000 Thunercat.
I know a guy that runs it on his 250 r for winter ice drags and basically that or hill climbing is the main purpose.
You need to have a good 12volt source, wire in an xtra fuel pump, run a 2# bottle about 60 seconds of continuous button use, which is a lot! Keep the bottle at 80 degrees for around 950#'s of pressure. A single cyl will be much easier than my triple cyl snowmo. Install time probly 3 hours. Don't let people BS ya the stuff works and if you don't run HUGE NOS jets you will be just fine for reliability. A bottle refil is like 7 bucks if I remember from last year.
It's fun stuff. However it is dangerous stuff too! All kinds of bad things can happen. (push button while idling? BOOM) et. Just need common sense... come to think of it
strike that last line! LOL.
Go to NOS's website they have much more info for ya there.
You can also try www.magnumforceracing.com they have kits too.
strike that last line! LOL.Go to NOS's website they have much more info for ya there.
Team Alba Racing has kits for Warriors. 600 bucks for 40 % more power it says. They have a bunch of stuff for warriors. Goto www.albaaction.com and youll find all your needs
