05 sportsman 500 clutch set up questions
Old Aug 4, 2005 | 06:16 AM
crasher22's Avatar
Default 05 sportsman 500 clutch set up questions
A while back it was posted that "On the SP's you don't even need a whole clutch kit. You can change the primary spring ($20) and change the secondary spring position (free) . This will have a huge affect on how it shifts and puts power to the ground."]
I was wondering if anyone could help me figure out what primary spring I should install . I am looking for more better throttle response and quicker acceleration, I do not care about losing top speed.
And what dose the "change the secondary spring position (free" mean and how do you do this?
My sportsman 500 is stock except for a k&n air filter, I ride alot of tight trails and mud at a elevation between 1500 to 8000 feet.
Any help would be great
Old Aug 4, 2005 | 07:51 AM
jimmypsp700's Avatar
Basically you would use a heaver rated primary spring to raise engagement.
Not good for tight, slow technicial riding.
Check other posts for spring color and rates, do a search.
Go one or two up from what your stock one is.
Jim
BTW, the '05 500s are clutched for low end acceleration, my buddies will pretty much keep up with my '02 700 til around 30 mph then bye , bye.
Old Aug 4, 2005 | 09:50 AM
Thor's Avatar
The Polaris white primary spring is what you want. You will not lose any top end speed. This spring will restore performance to quads which have had larger tires installed.
Old Aug 4, 2005 | 11:26 AM
Speedwerx's Avatar
Your stk. primary spring is a blue/grn if you wanted to change just the primary spring we wuggest running our green. On the secondary you have team cluthc on you quad so you cannot change the spring settings like the older models you would have to chnage the sec spring all together but the quads with the team clutches on them tend to perform better in stk. form if i were you and you wnat ed to go with the cheapest upgrade I would go with ou green primary spring for starters.
Old Aug 4, 2005 | 03:20 PM
stroker2's Avatar
Sorry Speedwerks....... 2005 500 HO have the Poo ebs roller secondary , not the Team ( 700 & 800 ) have them.
Old Aug 4, 2005 | 03:53 PM
Speedwerx's Avatar
Sorry for the bad info the 05 500 doesn't have the team you are correct in this case crasher you could change your sec. spring settings.
Old Aug 5, 2005 | 05:55 AM
crasher22's Avatar
Thanks for the help.
I am going to try the "white spring "
If you guys were closer the beer would be on me [img]i/expressions/face-icon-small-smile.gif[/img]
Old Aug 5, 2005 | 09:49 AM
stroker2's Avatar
tip # 2....Polaris EBS secondary has a compression spring, not the pre wind type, no position changes available.......you can only change the spring, EPI,Dalton and Heelclicker has springs available, none offered from HSP /SW. Tell Steve i said hi
Old Aug 5, 2005 | 10:45 AM
Speedwerx's Avatar
Stroker thanx fo rclearing that up I apolagize for the mistake.
toonces
Oct 16, 2019 12:11 PM
coldnorthpol
Jul 14, 2015 11:22 PM
coolguy420
Jul 10, 2015 01:17 AM
D-Hagz
Jul 4, 2015 02:19 AM
Shifts
Jul 3, 2015 07:59 AM
