350L carb question
Old Aug 4, 2005 | 04:58 PM
textrout's Avatar
Default 350L carb question
Hi gang, I need a little help:
I've got a serious gas leak under my 350L carb (1992 trailboss 350 2-cycle). I cannot see any orifice that it's coming from without removing the carb. Also, I've got the carb vent tube that will overflow gas if I get the tank very full at all. This all occurred when it quit running I think. Are these two things related, like from a bad float, or bad seal for the float tank, etc? Any help is appreciated!
Textrout
tml0002@unt.edu
Old Aug 4, 2005 | 06:23 PM
textrout's Avatar
Cornbread2, I think you just said what I needed to hear too. I might as well put in a new carb kit while I have it off. Thanks!
Textrout
cornbread2 said in another thread:
Your problem is with the float needle and seat.
You most likely have a piece of dirt or something in there or you could need a new needle and seat. Either way it is no problem to fix and it sure beats buying another carb.
Jmuddin284
Jan 19, 2026 07:16 AM
tweeder
Jul 5, 2015 01:57 PM
yambam13
Jul 4, 2015 01:49 PM
Mikea1978
Jul 4, 2015 12:37 PM
D-Hagz
Jul 4, 2015 02:19 AM
