Scrambler Chain Maintenance
Old Aug 5, 2005 | 06:50 PM
Ugonda's Avatar
Default Scrambler Chain Maintenance
As some of you know, I just got my 01 scrambler. It is my first chain drive ATV. What type of maintenance should I do to the chain? oil, etc. WHAT TYPE OF OIL DO I NEED TO USE? Also, how are the new chains different from the ones used on three wheelers? I have heard that the new chains are alot better?
Also, my bike does not have a chain tensioner. Do I need one? Why would I need one - jumping, etc.
Thanks again for all of your help
Old Aug 5, 2005 | 10:36 PM
scramblerXrated's Avatar
i use bel ray super clean o ring safe lube
X
Old Aug 5, 2005 | 10:45 PM
tyler711's Avatar
I use bar and chain oil, like you use on a chainsaw. I screwed one of those water-bottle squirt tops onto a 1qt bottle. Just pour it on the chain as I push the quad.
I don't know if that's what most use, but it's worked for me. I do it about every ride because I am mostly in the mud and the chain is usually scraping in the dirt (damn solid axles).
Old Aug 5, 2005 | 11:41 PM
XtremeSkier's Avatar
i just use polaris chain lube
Old Aug 6, 2005 | 01:02 AM
ftwflh's Avatar
Polaris chain lube with a HPD chain tensinor and the adjustments are few and far between
Old Aug 6, 2005 | 03:24 AM
nez02's Avatar
I use the Bel Ray chain lube. No matter what kind you use, you want to make sure it sticks to the chain.
Nez
Old Aug 6, 2005 | 12:41 PM
Fixitmatt's Avatar
i would get the HPD chain tensioner it was save you mony on chains. other wise you'll have to buy new chains offen.also use bel-ray chain lube or they use to have a wax spray that was good too
Old Aug 6, 2005 | 01:33 PM
OffRder15's Avatar
I also suggest a HPD chain tensioner. As far as lube I just use the Polaris stuff or Tri-Flow.
Most importantly, DO NOT NEGLECT YOUR CHAIN. I see too many people on the trails who never adjust their chain and forget about even checking it before they ride. Not good.
Old Aug 6, 2005 | 02:21 PM
MnFriesen's Avatar
We use the polaris cain lube on our trailblazer....
Old Aug 6, 2005 | 10:30 PM
garrett5462's Avatar
i either use pj1 or just some motor oil.
Nosparkpolaris
Sep 20, 2015 04:21 PM
caveeagle
Sep 19, 2015 01:20 PM
merryman
Sep 19, 2015 03:15 AM
1000gade
Sep 9, 2015 03:35 PM
bmark0610
Sep 7, 2015 09:42 PM
