battery goes flat
Old Aug 7, 2005 | 08:04 AM
aussiedslover's Avatar
Default battery goes flat
hey there guys
my battery keeps goin flat on me if i let the bike sit any longer than about 2 weeks . i have already had it at the auto electics and they replaced my temp switch but it happen again today its starting to drive me nuts. i have had the battery checked and it is alright its got me stuffed!! so thats why iam asking the gods of the ds's for help
thanks all matt
Old Aug 7, 2005 | 01:06 PM
hondabuster's Avatar
For now, you can disconnect the battery when not being used,or hook up a battery tender.
If you have a volt ohm meter, you can disconnect the battery positive cable, and with the key off, put the voltmeter in series, and measure the dc amps, that are flowing when off. Each type of quad is different, and some have memories, and some have digital clocks and such, but roughly, there shouldnt be more than 50 miliamps flowing. If its more than that, youve got something draining the battery.
From there, start disconnecting connectors, until you find the circuit which has the leak. leave the meter hooked up, and when the amps drop, you found the circuit.
bzdok1234
30
Feb 23, 2016 01:55 PM
Hunter100us
Oct 7, 2015 11:46 PM
scram5050
Sep 3, 2015 05:06 PM
cody500ho
14
Aug 14, 2015 05:03 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
