350X battery Conversion Help!
Old Aug 8, 2005 | 10:29 PM
MY86ATC350X's Avatar
Default 350X battery Conversion Help!
on my 350x i installed a battery so i can run my lights when i shut it off, i need this feature because i mostly ride at night after work, and when im riding my 350x i stop to take a break but i have no power to my lights to see.
i have everything installed but except the wireing, im scared that if i connect the battery ill burn out generator, i saw on left case there is a red connector thats for the ignition and the other clear one is for the lighting, and thats where i have to connect the battery to pick up power,
so my question is will i burn out the generator if i connect it there or i need some kinda volt. regulator?
Old Aug 10, 2005 | 03:06 AM
now it looks like i burned out my voltage rectifier. (regulator) the lights power up but when i connect the regulator the light dimmmm all the way, they stay so low like if your battery is low. can some help me on this??
Old Aug 11, 2005 | 05:02 AM
ThrashAndCrash's Avatar
OK....no one has jumped in to help, so I have to take a crack at it...........
Did you buy some kind of "kit" to install this battery conversion, or is this a homemade design.....What have you installed so far; other than the stock items that came on the trike.
Old Aug 11, 2005 | 01:37 PM
no its not some kit. i just removed the battery of my blown pocket bike and its 12V-14.4V, its a homemade design. the battery is small and cool it fits right inside the airbox. so far everything is still the same im just not sure of connecting it to the harness. i think it will send charge to the stator and burn it out.
Old Aug 14, 2005 | 09:13 PM
TecateKtx250lover's Avatar
if that dosent work you can always use duct tape and a flash lite [img]i/expressions/face-icon-small-smile.gif[/img]
Old Aug 14, 2005 | 10:48 PM
RIGHT!!!!!! But no..
toonces
Sep 5, 2015 01:14 PM
Pahuntman
Sep 5, 2015 11:07 AM
scottdubya83
Aug 29, 2015 04:08 PM
Nazz26
Jul 30, 2015 11:51 AM
KingDingalling
Jul 29, 2015 10:55 AM
