lt80movable drive face?
Old Aug 15, 2005 | 09:04 PM
NORCAL68's Avatar
Default lt80movable drive face?
i can not remove mine of the shaft. i can only move it about half an inch. i do have the service manual
it just says to remove it.thanks for any help!
Old Aug 16, 2005 | 09:12 AM
LT80's Avatar
LT80 Expert
The roller plate has squeezed onto the crankshaft. Prolly a installation problem with the keyway.
Try to pry it off, but pry on both sides at once. You don't want to bend the crank.
Old Aug 17, 2005 | 12:21 AM
NORCAL68's Avatar
thanks lt80 , got home read your reply went out and yoused a puller very carefully it came right off thank you. checked all my rollers and each one has some sort off flat spots i guess i need new ones? how and where do i get new ones? thanks
Old Aug 17, 2005 | 02:45 PM
LT80's Avatar
LT80 Expert
Yes you need rollers.
Get them at a Zuki dealer. You only need 4 of them in there. (4 bucks each)
Check the plate that covers the rollers. If grooved where the rollers run, get that piece also. (approx 5 bucks). [img]i/expressions/face-icon-small-smile.gif[/img]
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
