700 EFI Help Tbap Connector...
Old Aug 15, 2005 | 10:11 PM
bugmanjr3351's Avatar
Default 700 EFI Help Tbap Connector...
This Is Kinda A Repost...
I need some help with the wire position's on the Tbap connector on my 04 700 EFI.. The four wires that go to the connector pulled out on me and I have no idea which order they go back in the plug. Each hole in the plug is labeled with a number 1, 2, 3, and 4. I was wondering if someone with this same connector could look at their's for me and let me know which color wire goes with which number.
Treacherous already responded to me on a previos thread(Thanks Again!), but unfortunately he could'nt give me a exact answer because he has done repair work to his plug. FOR ALL EFI OWNERS THAT DON"T KNOW WHICH SENSOR THIS IS, it's the one just past your air box. It has 4 wires, pink/white, pink, orange and purple.
Thanks...
bug
Old Aug 16, 2005 | 12:09 PM
It's funny how many people have the same bike but won't go out and check the wire's!
Thanks...
Old Aug 16, 2005 | 02:44 PM
mbDSA's Avatar
1. Purple - Sensor Ground
2. Pink/White - Air Temp Signal
3. Orange - 5V Sensor Supply
4. Pink - Barometric Pressure Signal
Old Aug 16, 2005 | 02:46 PM
mbDSA thanks!
after 5 days I found someone to help me out...
Thanks Again mbDSA
Old Apr 22, 2015 | 10:21 AM
polaris warrior's Avatar
Default tbap wire repair
hello weekend warrior,i have a 2009 700 ranger and found the wires broke on the tbap sensor.was wondering if i could purchase your repair kit for that sensor
Old Apr 22, 2015 | 11:28 AM
10 year old posts,sometimes people just disappear over time. Common problem on the efi machines. Polaris sensor harness repair kits are junk as I've installed many. Same thin wiring and connectors on the kits as what's already on the machine.Designed to fail again. There's a "sticky post" at the top of the expert section on 700/800 efi wiring problems,but includes the 500 also whether a Sportsman or Ranger. Good posts to read.The member that started this post sells better connectors and stronger wiring kits. The place to get heavier duty repair kits is here.Only The Best
Old Apr 22, 2015 | 12:16 PM
thanks for the reply,will order one today,do they also reprogram ecu ?
Old Apr 22, 2015 | 12:21 PM
That can only be done at dealers with Polaris Digital Wrench software. On reflashing the ecu,most dealers charge around 1 hr labor as it does take some time.
Old Apr 22, 2015 | 12:22 PM
ok thank you
Pennyrile_Energy
May 15, 2015 06:55 AM
ccobra70
Jan 7, 2015 01:48 PM
diggerd
Aug 22, 2009 09:36 PM
springtuckyn
Dec 2, 2006 08:10 PM
bugmanjr3351
Aug 15, 2005 08:45 PM
