Rubicon Grease Fittings
Hi All:
New to the forum & quads but this is the place.
I am riding a new Rubicon and am wondering where, if any, are the grease fittings and what type of tire pressures are you all running.
I ride in the woods mostly and the mud when I can find it!
Thanks!
Thanks!
Likely there are no grease fittings. My '98 forman has none, honda typicaly goes with a sealed design in that if there's no place for grease to leak out, there's no place for water and dirt to get in. I guess it works, in 7 years, I've never had to replace a suspension joint, bushing or ball joint!!!
Welcome to the forum!
There are no grease fittings and I usually run about 3 psi in my tires. If I ride is loose sand or very rocky terrain, I will drop it down to about 1-1/2 - 2 psi. It is all about preference. I know guys that run over 5 psi and some that run no more than 2 psi. I have had good sucess with 3 psi in most conditions.
