lt80 helix
Old Aug 16, 2005 | 07:57 PM
ltdaddyo's Avatar
Default lt80 helix
hello forums. can anyone tell me if changing the rear spring on the lt will give a better shot out of the hole front and rear are hetrick modfied but the stock helix remains any input will help thanks...
Old Aug 16, 2005 | 10:48 PM
ltdaddyo's Avatar
Default lt80 helix
lt helix.......or will it affect my stall speed if i change it from the stock one?????
Old Aug 17, 2005 | 01:22 AM
mrdirt's Avatar
Default lt80 helix
I have motor and clutch mods by Jack (LT80) and he changed the rear spring. I don't know if his new spring has a different tension or not (you should ask him) but it pulled hard right off the line, in fact it would wheelie off the line on our lawn. I'm not sure if the new spring helped or not since I didn't compare the difference. However, I decided it was time to change the drive belt since it seemed a little worn. That new belt made it slow off the line. It would take about 2-3 seconds to ramp up and then engage hard. I measured the difference and it was about 2mm wider then my old belt. Went back to the old belt and bam off the line again. Too bad nobody sells a narrow race belt for the LT80.
Bob E.
Oct 1, 2019 09:08 AM
QuadRiders
Oct 22, 2015 04:13 PM
merryman
Sep 19, 2015 03:15 AM
Jaymc
Sep 11, 2015 07:45 AM
Bergmann
Aug 13, 2015 03:51 PM
