No spark???
Old Aug 20, 2005 | 12:59 PM
fastasyoucango's Avatar
Default No spark???
This morning, I was letting my 2000 400ex idle to warm it up and all of a sudden it just died. I tried to start it back, but nothing. I took the spark plug wire off and stuck a plug in it and grounded it and turned it over, but no spark. I checked all of my connections and grounds, they seem fine. What could be the problem? I know I'm getting fuel. I have a book on it, but it's showing you need a special part (some kind of little white box with wires) to check the ignition system voltage. Anything would be greatly appreciated!!!
Old Aug 20, 2005 | 04:31 PM
Default No spark???
Could it be the CDI?
Old Aug 21, 2005 | 09:55 AM
Default No spark???
Well, a friend of mine let me try out a cdi off his 400ex and it didn't work. I read macgiver's post about this. It seems I have a long road of testing to do.
Old Aug 21, 2005 | 10:50 AM
Default No spark???
I took the coil off and checked for continuity between the black/yellow wire and the spark plug wire. At first it showed continuity. I checked it a couple more times and it was still ok. I checked it one more time and it showed nothing. I had the meter on 200 ohms. I switched the meter untill it started picking up again and then it showed 180,000 ohms. I moved the wire around trying to get it to pick up better, but nothing. Could this be the problem???
Old Aug 21, 2005 | 10:56 AM
trx300exrider's Avatar
Default No spark???
did u try to hold the clutch in then start it
Old Aug 21, 2005 | 11:50 AM
Default No spark???
Doesn't that only effect the cranking of the engine? It cranks fine, just no fire. Anyway, I connected the coil to a battery to see if it would fire a plug and it fired it just fine. So, I guess it's working. This is driving me crazy!!!
fordfaithful21
Dec 7, 2015 05:52 PM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
MrTrashMan2U
Sep 9, 2015 11:11 AM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
