raptor660 carb question?
Old Aug 22, 2005 | 08:32 PM
Ricke's Avatar
Default raptor660 carb question?
on the clip on where do you put it for it to be at the richest setting?
Old Aug 22, 2005 | 08:56 PM
Ozark38's Avatar
You move the CLIP down for a richer setting which in turn raises the needle.
Old Aug 22, 2005 | 09:19 PM
maddog56's Avatar
The higher the needle the less obstruction in the carb, so when the clip is at the lowest point its at maximum flow.
Old Aug 22, 2005 | 10:57 PM
Ricke's Avatar
thanx and one more question, how could i get a almost stripped screw out of the top of the carb? any tricks?
Old Aug 22, 2005 | 11:16 PM
Storj's Avatar
how is it striped the top of the bolt? or are the threads striped if it is the bolt then a pair of vise grips or get a dremel and make a slot for a screw driver if its the threads that are striped then you need to drill it out and tap it to the next size
Old Aug 22, 2005 | 11:22 PM
Ricke's Avatar
its the top of the srew but i dont want to try to clamp on to it, theres not much to grab on to and it like right on the carb so i dont want to wreak anything!
Old Aug 22, 2005 | 11:58 PM
2FAST4U69's Avatar
This happend to me this weekend, with the float bowl screws. I used the smallest pair of vice grips I could find. I cant believe how soft those are.
Old Aug 23, 2005 | 12:01 AM
Raptorboy4life's Avatar
For the float bowles.. i stripped 1 myself.. i took a really really small hack saw and i cut a straight cut, then i took out a flat screw driver and unscrewed it lol.
Old Aug 23, 2005 | 08:33 AM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
i have had great success using my 14.4 dewalt drill with the torque setting between 1 and 2
the tap, tap, tap action with a new bit tip (at slow speed) has yet to be duped
it works surprisingly well for carb screws
Jmuddin284
Jan 19, 2026 07:16 AM
200es
Jul 10, 2015 09:09 AM
tweeder
Jul 5, 2015 01:57 PM
yambam13
Jul 4, 2015 01:49 PM
Mikea1978
Jul 4, 2015 12:37 PM
