200x carb problem
Old Aug 30, 2005 | 05:47 AM
Jammerz's Avatar
Default 200x carb problem
I have 84 200x, does not idle correct and smokes (rich) when you gun it. I have cleaned the carb and tried various settings on the mixture screw but does not seem to make a difference. I was thinking the float was too high but it is a plastic unit and don't see how you can change the height. Any ideas are appreciated
Jammer
Old Aug 31, 2005 | 05:02 PM
bigblock2stroke's Avatar
Sounds like idle mixture screw.
Is plug wet?
Does it smoke all the time or only when you gun it?
Blue, black, white smoke.
Sounds like top end rebuild time, head re-valve, something like that.
Sorry I can't be more help.
Do a compression check to see if its oil blowby.
Old Aug 31, 2005 | 07:48 PM
Jammerz's Avatar
Mixture screw has little or no effect,
Black smoke, like rich can almost smell fuel.
Doesn't smoke all the time.
Old Sep 2, 2005 | 01:59 PM
rebuild the carb
surprisingly easy, just make note of how many turns are on each adjuster so you can reset them when you are done.
needle clip might be set too high, try dropping it one slot/position.
Old Sep 2, 2005 | 11:16 PM
1bad450r's Avatar
Mixture screw should be about 2 turns out I believe, and try what bigblock said and move your needle down one notch. Let us know what happens.
Old Sep 7, 2005 | 09:17 PM
haywoodjalikme's Avatar
Take the carb apart and blow air through the jets and all passages!
1984 specs(for a stock engine!)
Pilot screw out 2-1/4 turns
Main Jet-108
Needle clip 4th groove from the top
Float level 14mm
I can't recall what the pilot Jet should be.....35 or 38???
Jeff
200x hill climber
Ask the Editor
Jun 10, 2015 11:11 PM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
kevbowe
Jun 1, 2015 01:17 AM
bigmanm
Jun 28, 2000 10:34 PM
