intermitent no spark
Old Sep 1, 2005 | 02:51 AM
fairlane's Avatar
Default intermitent no spark
I just bought a ds 90 for my daughter, and after riding it for a day it just quit.
I checked all the connections and used my multi meter to check the stator and wiring, everything looks good. I put it all back together and tried it and it started but only ran for about 10 sec then no spark again, so I left it for awhile and tried it again and it started but stalled and then back to square one. would a cdi do this? I thought once they went its over.
thanks for any help.
Old Sep 1, 2005 | 03:06 AM
Hightower's Avatar
perhaps the plug is fowled badly, if so the spark will be week and intermitent. sometimes even cleaning a badly fowled plug will not help, try a new one. you can hold the plug against the case to ground it adn visualy check spark, then plug a new one in and see if its looks stronger.
old or bad gas can cause the plug to fowl almost immediate, so if a new plug gets fowled right away try draining the tank and using fresh gas and a new plug.
these are just little easy things to rule out. one time I bought a can of gas from a local station that was no good and I spent an hour troubleshooting before I figured it out.
Old Sep 1, 2005 | 04:14 AM
fairlane's Avatar
I forgot to mention the plug is new and clean and if I hold it to the case I still get no spark.It also looks like it has a new ignition coil and key switch so I am assuming this has been a ongoing problem.
Another thing is the battery is stone dead, I have tried to boost it, but should this matter if I am kickstarting it.
This thing is driving me nuts.
thanks
Old Sep 1, 2005 | 04:20 AM
ThrashAndCrash's Avatar
check the wires where they go into the stator cover............Ohm them out, then wiggle the wires with the ohm meter attached...........I have owned 3 bikes now that ALL went bad in that area.....same spark prob as yours .......! and ohm out the plug wire to make sure you boot has a good connection!
ALSO check the wires at the start switch.........could be coming loose!
Old Sep 1, 2005 | 04:24 AM
ALSO.....welcome to the forum!!!!
Old Sep 1, 2005 | 04:52 AM
fairlane's Avatar
trashandcrash
were you able to repair the wires or did you replace the stator?
thanks
Old Sep 1, 2005 | 05:33 AM
I repaired the wires............cut back the coating......slid some "shrink tubing" (can get the best price at radio shack) over the seperate wires, and soldered them together. then I took the shrink tubing slid it over the sloder connection, shrunk the tubing, and good to go!
About $1.50 max..........
Old Sep 2, 2005 | 10:40 PM
fairlane's Avatar
Thanks again I'll check the wires when i get home.
fordfaithful21
Dec 7, 2015 05:52 PM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
MrTrashMan2U
Sep 9, 2015 11:11 AM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
