Front End Allignment...
Old Sep 3, 2005 | 10:46 AM
garrett5462's Avatar
Default Front End Allignment...
i just changes the tierod ends on my z and was wonderiing, when you allign the front wheels do you want them perfectly strait with the rears or tilted in/out a little.
Old Sep 3, 2005 | 12:27 PM
quad2xtreme's Avatar
tilted in some. Check a manual if you have access to one. Rule of thumb on a sport quad is the front portion of the front tires from center to center should be 1/2" closer than the back portion of the front tires. I usually use a couple of straps to make sure the steering wheel is perfectly centered.
Make sure the 1st side you do is straight first then come in about 1/4" then adjust the other side. I have seen people start with the first wheel out of whack then match the 2nd only to have a quad that goes left or right when the steering wheel is straight.
/Jon
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Aug 6, 2015 10:46 AM
toonces
Aug 5, 2015 05:55 PM
carolinabomb
Jul 26, 2015 08:40 AM
tporath
Jul 11, 2015 12:31 PM
