Secondary Clutch Disasembly
Old Sep 8, 2005 | 12:08 AM
Polaris500HO4x4's Avatar
Default Secondary Clutch Disasembly
Could anyone possibly give me a discription of how to take apart my secondary clutch to replace the buttons?
What do these buttons look like, and how much do they cost.
Old Sep 8, 2005 | 01:59 AM
Backinthesaddleagain's Avatar
The first thing is to get a GOOD set of snap ring pliers. Get a set with long handles to give good leverage........it makes a world of difference.
Pull the secondary off, remove the snap ring on the back. The helix and spring will come right out. The 3 buttons are screwed into the clutch housing. They are easiliy removed and replace. They cost about $3 each. If you replace them before they disintegrate, the helix ramps will not get scored and you can still use the same helix......otherwise a new helix costs about $43. Re-install and pre-tension the spring by rotating the helix counter-clockwise 1/3 turn before pushing it all the way down into place. Have somebody else re-install the snap ring while you hold the assembly in place. Then put the clutch back on the machine.
If you have the proper snap ring pliers it's pretty easy.
Old Sep 8, 2005 | 02:07 AM
jimmypsp700's Avatar
I second that and MAKE SURE you get that good set of snap ring pliers!!!!!
two people helps with reassembly.
dont forget to preload the spring in non ebs secondarys.
Jim
Old Sep 8, 2005 | 08:31 AM
xsmoker's Avatar
HA, when I took mine apart I only had a small set of snap ring pliers laying around and thought they would work. They did but they kept popping off the ring, finally got off. This is one of those times where the proper tool is required.
Old Sep 8, 2005 | 09:01 AM
what do these buttons look like because my dealer gave me the wrong thing im pretty sure... i got a bag of 3 and he charged 16 bucks for them
Old Sep 8, 2005 | 09:57 AM
rieds's Avatar
i would recommend the Hpd clutch buttons as apposed to the stock ones.
Old Sep 8, 2005 | 10:39 PM
Thanks alot guys [img]i/expressions/face-icon-small-happy.gif[/img]
One last thing
what do these secondary buttons look like... if someone could post a pic before i tear into the clutch i think my dealer gave me the wrong thing
Old Sep 8, 2005 | 11:59 PM
ftwflh's Avatar
They look like plastic ramps
Old Sep 9, 2005 | 01:04 AM
ok because my dealer gave me something that looks like a rootbeer barrel with a hole in the center
Old Sep 9, 2005 | 04:42 AM
Kinda Y shaped if your talking non EBS machine . They are like rollers in teh EBS secondary.
I have pictures HERE
Jim
