Secondary Clutch Disasembly
Old Sep 9, 2005 | 04:45 AM
jimmypsp700's Avatar
Default Secondary Clutch Disasembly
I mean HERE (for real)
They (2 of 3) are next to the reed and piston. From my non ebs scr400.
Jim
Old Sep 9, 2005 | 09:02 AM
Polaris500HO4x4's Avatar
Thanks for the help jim, my dealer did give me the wrong thing
Old Jan 10, 2006 | 12:31 AM
Lukester's Avatar
I thought I would change my secondary spring to red. The instructions above look good and I think I'll give it a try.
How can I set the secondary to 2-2 in the process when I change the spring? I don't know what 2-2 means or how to do it to be honest? I saw someone else with a similar clutch set up and thought I would try it.
I changed my front to something stiffer and it has a higher take off, hits good and pulls good throughout. I think it could shift out better to higher RPM's near the top of hills though.
Thanks
Old Jan 10, 2006 | 02:53 AM
The #1 position on sheave is the stiffest setting with the #2 and 3 settings progressively weaker .
On the roller housing (or helix) the #1 position is the softest setting and the #5 (2) is the stiffest.
Just place the spring end in the appropriate hole and reassemble.
Don't forget to preload the spring on non ebs machines buy turning it 1/4 to 1/2 turns before reassembly.
Jim
Old Jan 10, 2006 | 10:10 AM
  #15
Lukester's Avatar
jimmypsp700,
Ok, I'll give it a try. I've seen the secondary but not in a while so I'm having trouble picturing this. With the info on this thread I'll figure it out when I break into it. I know what the sheave and helix look like and how to pre-load.
Thank you
Old Jan 11, 2006 | 02:43 AM
  #16
Go to www.polarisowners.com and download a PDF. file of the parts manual, it has a good diagrams to go by and a list of all the parts, although its not sopposed to be used for assembly you can get the idea.
Jim
also see my photos here...http://photobucket.com/albums/y148/jimmypsp700/700%20PVT/
Old Jan 11, 2006 | 09:35 AM
  #17
Lukester's Avatar
jimmypsp700,
Very good. Thank you so much.
Old Jan 12, 2006 | 02:48 AM
  #18
Your welcome.
BTW that's one trick looking TBoss with those wheels and tires on!
Jim
Old Jan 12, 2006 | 04:02 AM
  #19
robedoll's Avatar
Originally posted by: jimmypsp700
I have pictures HERE
Jim
Tell me more about the chrome header that I see in your pics? Will this fit an 06 800? What brand and where to get? I saw an 06 800 on EBAY and it had a chrome header on it. I have been unable to locate one on the net.
THANKS
Robert
Old Jan 12, 2006 | 05:12 PM
  #20
That is a '05/06 sp800 head pipe, the other is a 700 with the Y manifold.
Just take yours off and send it to Jet Hot for the Sterling (ceramic) coating.
Or a local shop, it will cost you around $100 to do, they are new for about $100 black.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
