how does it work?
Old Sep 11, 2005 | 10:13 PM
snowbuster's Avatar
Default how does it work?
What’s the deal with this clutch on the new 250ex? No stall? So how are you suppose to know if you are using it right? Can anyone please explain this system?
Old Sep 11, 2005 | 10:19 PM
250exRiderMatt's Avatar
basically the difference is that when the engine rpm gets low enough the clutch plates will disengage and that will prevent you from stalling the ngine because it will allow the engine to spin freely again. i guess the problem is knowing if your using it right. hopefully my explaination makes sence so you
Old Sep 11, 2005 | 10:28 PM
snowbuster's Avatar
So basically at idle it has no effect but anything higher and it works like normal, meaning you have to use it for shifting but not for starting and stopping?
Old Sep 11, 2005 | 10:44 PM
you CAN use it for everything to keep the rpms up and be faster, or you can use it like a semi-auto. but at idle yea the clutch disengages without the handclutch
hugemoth
Jul 20, 2020 03:28 AM
rcappie4
Jul 18, 2015 07:51 AM
timster911
Jul 13, 2015 01:57 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
