rancher es rear shock
Old Sep 13, 2005 | 01:17 PM
punky's Avatar
Default rancher es rear shock
My dad has a 2005 rancher 350 es and would like to soften up the rear shock or replace it with a softer shock. Has anyone done this? Where are parts available? Thank you.
Old Sep 13, 2005 | 05:53 PM
LittleBill's Avatar
haven't heard anything but Works shocks, too rich for my blood at 400, thought there was some talk about a recon or forman shock
Old Sep 13, 2005 | 09:19 PM
ixRAZORxi's Avatar
Heat the spring evenly with a torch and it will lose temper and soften up. Take the shock off first . Take the spring off if possibble. I don't think you can on a rancher though. Try to direct the heat away from the main part of the shock and just on the spring.
I would start at the bottom and heat it up about 2 inches up. Put it back in and see if its soft enough. If not heat a few more inches up. You can't get the temper back once it's gone. If you don't heat evenly you may cause a soft spot to form and the spring will break.
I wouldn't try it though. I would just buy a softer shock off a sport quad the same length.
Also bigger tires with low air pressure will soften it up too.
Bratman2
Aug 6, 2022 01:42 AM
STLyamwar
Jul 25, 2020 04:44 AM
Dammar
Aug 26, 2015 07:12 PM
07Redrider400
Jul 25, 2015 05:31 PM
cSchwartz
Jul 9, 2015 02:40 PM
