Greasing rear axle bearings on Scrambler 500...
Old Sep 14, 2005 | 03:02 PM
ScrammyUK's Avatar
Default Greasing rear axle bearings...
Reading the service manual it says lubricate eccentric housing...until grease is purged on each side of the eccentric. Does this mean that when there is enough grease in there I'll be forced out on both sides of the bearing housing? I've pumped a fair bit of grease in there thru the nipple but don't see any yet...does this area just take a LOT of grease? Where exactly will I see it when it is full - will it come out between the housing and the disk on one side and between the housing and the chain sprocket on the other?
Thanks for any advice,
Chris
Old Sep 14, 2005 | 08:02 PM
ScrammyUK's Avatar
Default Greasing rear axle bearings on Scrambler 500...
Anyone? I'd like to know as I've already had to replace the rear axle bearings once, and that was after only 4 months use. According to the dealer it was becasue all of the grease had disappeared...
Old Sep 14, 2005 | 11:01 PM
user3657's Avatar
yes keep pumping. it will come out the sides.
Old Sep 15, 2005 | 02:05 AM
Temper50's Avatar
Yep that's what I did, it took like 14 pumps on the grease gun!!!!!
Ean
Dec 19, 2022 08:48 AM
DeFox500
Jul 26, 2015 06:32 PM
Peter_
Jul 18, 2015 07:06 AM
maxjung
Jul 13, 2015 05:11 PM
Rider252
Jul 6, 2015 03:37 PM
