what numbers actualy matter on tires ?
Old Sep 24, 2005 | 04:59 PM
zoom545's Avatar
Default what numbers actualy matter on tires ?
Ok im boght to get new tires and they have 22 -11-9 and my rims are 22-10-9. will these fit and also what numbers actaully mateerm . thanks
Old Sep 24, 2005 | 07:08 PM
maddog56's Avatar
First number is the tire diameter; distance from ground to top of tire when the tire is sitting on a bike.
Second number is tire width; distance from one side of the contact patch to the other.
Third number is rim size; A tire will have a hole in it for a rim, the diameter of this hole is the rim size.
Your rims arent 22x11x9, especially considering there are not 3 numbers in a rim size and no rim for an atv measures 22" in any dimension.
For a rim there are two numbers, the first is the diamter and the second is the width. usually there is a third set of numbers expressed as a pair. ie: 3+5, which indicates the offset of the mounting surface of the wheel from the edges of it.
Old Sep 24, 2005 | 10:09 PM
zoom545's Avatar
My bad i ment that my tires are 22-10-9, i was just wondering if the 22-11-9 tires would fit on my rims
Old Sep 24, 2005 | 11:40 PM
87250xman's Avatar
They should work fine.
switzomatic
Aug 24, 2015 12:57 PM
BigT137
3) General Discussions..
Aug 19, 2015 12:09 AM
2007 Grizzley 450
Aug 13, 2015 06:33 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
Jul 24, 2015 11:57 AM
