hub stud
Old Sep 28, 2005 | 01:03 AM
CHacHie1226's Avatar
Default hub stud
does anybody know where i can get a hub stud for an 01 250 2x4 with the disk mount? one of mine broke.
Old Sep 28, 2005 | 03:09 PM
Bear4570's Avatar
Default hub stud
Need a better description of what you need or go to here and give a item or part number. The wheel and hubs are the last item on the list.
http://www.brownsleisureworld.com/fr...2001ATV2502x4/
Old Sep 28, 2005 | 03:29 PM
Default hub stud
i need one of the studs (bolts) that the wheel slides on to and that the nut that the wheel is held on by screws on to.
Old Sep 28, 2005 | 03:51 PM
Bear4570's Avatar
Default hub stud
The are not sold seperately from the hub by AC. Find a nuts and bolt supply house, yellow pages under nuts or bolts, and take the broken one to them. They should be able to help. BTW the bolts that hold the disc to the hub don't go all the way thru the hub.
Old Sep 28, 2005 | 05:48 PM
Default hub stud
do i need all four of the bolts that hold the disk on?
Old Sep 28, 2005 | 11:01 PM
Bear4570's Avatar
Default hub stud
If the others are ok, then no. But bolts are cheap and new won't hurt anything.
Old Sep 28, 2005 | 11:54 PM
Default hub stud
but where do i find a bolt with the right thing on the other side for the disk mount screw to thread in to?
Dabears1983
Jun 16, 2015 12:17 PM
ATV_MAN
Oct 21, 2001 04:08 PM
dirtclog
Jun 12, 2001 06:42 PM
Glen
Nov 23, 2000 07:18 AM
Coach2U
Nov 14, 2000 11:28 AM
