Toe-out correction?
Old Sep 28, 2005 | 09:55 PM
Turn3's Avatar
Default Toe-out correction?
Eton 90
Is there anyway to correct a slight toe-out? I would much rather it have toe-in..
Old Sep 28, 2005 | 10:49 PM
spike99's Avatar
For TOE adjustment instructions, surf page 37 & page 38 within:
http://webzoom.freewebs.com/miniatvs/Viper%20Manual.pdf
To adjust the TOE, loosen the both lock nuts on the Tie Rod, and turn both Tie Rods the same amount. Then, tighten the lock nuts back down. One lock nut is normal thread direction and the other is the opposite hread direction. For safety, you should consider using the TOE adjustment measurements that are within this Service Manual. Having too much TOE IN is dangerious.
Hope this helps...
Old Sep 29, 2005 | 11:53 AM
Raptorlegs's Avatar
T Rex Rider
What irritates me is!
Those 6-packs work pretty good.
Depends on the quad but too much toe-in can make it REAL squirley and more prone to rollover.
Old Sep 30, 2005 | 04:08 PM
LT80's Avatar
LT80 Expert
I like the toe-in to be a light 1/8th inch.
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
1ArmBandit
55
Oct 14, 2015 09:03 PM
2many2ride
Sep 27, 2015 04:35 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
MrTrashMan2U
1) Engine problems..
Sep 9, 2015 11:11 AM
