timing chain or not?
Old Oct 4, 2005 | 08:48 PM
300exfreak's Avatar
Default timing chain or not?
i ahve an old honda hotor it runs good dosnt smoke but when its at idle you can hear a clicking noise.could this be cause by the timing chain?
Old Oct 4, 2005 | 08:55 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Could be, could also be valves that need adjusting.
Old Oct 4, 2005 | 08:58 PM
300exfreak's Avatar
has anyone hear of the timing chain breaking or needing replacedvery often?
Old Oct 4, 2005 | 09:01 PM
KTM Patrol
Former Chinese POW!
It can happen but is rare.If it does hapen it will be expensive. What kind of honda engine you got?
Old Oct 4, 2005 | 09:03 PM
300exfreak's Avatar
its a 200 model 300ex engine
Old Oct 4, 2005 | 09:15 PM
KTM Patrol
Former Chinese POW!
I would check the valves.
Old Oct 4, 2005 | 09:18 PM
300exfreak's Avatar
im pretty green on engines is it difficult to adjust these valves.could you tell me how to go about checking them? any info would be greatly appreciated
Old Oct 5, 2005 | 03:58 PM
robnhouston's Avatar
If the timing chain doesn't break it could jump some teeth. In that case it'll bend the valves. In a couple I've done the tensioner was still good but the chain was stretched and jumped. It will make a lot of noise before it goes, usually more at idle.
Old Oct 5, 2005 | 04:13 PM
KTM Patrol
Former Chinese POW!
Itsnot that tough to do. you will need to pull the valve cover and find TDC,(top dead center) when the piston is at the top of the stroke. Then you need to stick a .002 thick feeler gauge between the valve tip and the rocker arm. If its tight you need to loosen the valve and if loose you neet to tighten the valve. It would help to get a manual for your machine but it can be done with out one.
Old Oct 6, 2005 | 11:44 AM
KTM Patrol
Former Chinese POW!
300exfreak, if you want to try this and dont want to buy a manual I could type out some fairly decent instructions for you. Jusy let me know and I will.
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
95wolv
Jul 17, 2015 08:13 PM
Sjrpp
Jul 5, 2015 09:04 PM
