Looking at 3 used Warriors this weekend. What should I look for?
Old Oct 27, 2000 | 10:08 PM
jefffoxsr's Avatar
I will be looking at 3 Warriors to buy this weekend. Two of the three Warriors owners claim "low hours". What can I look for as far as wear items to substantiate the claims? Also, on a Warrior, what should I look for on the quad as a sure sign not to buy?
Thanks
Jeff Fox
Old Oct 27, 2000 | 10:41 PM
hot_shoe_cv's Avatar
One thing to look for are worn bearings, by jacking up the rear wheels and attempting to detect play by grasping the tire at 9:00 0'clock & 3 0'clock & wiggling the tire toward you & away from you. Then by doing the same at 12:00 0clock & 6 0'clock . If play is detected, bearings are likely worn & need to be replaced.
Another spot to look at is where the frame down tubes join the side rails. This is a common location of cracks in the Warrior frame, about an $800 to replace.
Another is to check the filter condition and pull it to look into the air intake for signs of dirt. If the filter is a stock one, dirt is a good possibility and signs in the intake means that there is probably dirt in the engine..bad news!
Those ar a couple of less obvious signs of poor maintenance aside from the more obvious cosmetic ones
Old Oct 28, 2000 | 12:32 AM
Zorro's Avatar
Yep. Maintenance is the main thing.
If the guy doesn't seem to have done much on his atv, forget it. I did this error on a 2 year old banshee, and I've had troubles for 1 month. When I say troubles I mean that I couldn't complete a ride without breaking... Now it works fine.
Scooter's Shop
Oct 9, 2015 02:09 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
bvolks
Sep 13, 2015 12:57 PM
