KAZUMA FALCON MKII VALVE ADJUSTMENT
Old Oct 19, 2005 | 12:32 PM
cl440's Avatar
Default KAZUMA FALCON MKII VALVE ADJUSTMENT
I see it says to adjust the valves on my Falcon 110 MKII. I cant find what they want the valve lash to be adjusted to? Do they make a service manual for these ATV's? Does anyone know the setting?
Old Oct 19, 2005 | 01:48 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
I tried to get a valve adjustment spec for my wifes Yamoto 150 for 3 months. I gave up and adjusted them to .002 cold just like all my honda thumpers.
Old Oct 19, 2005 | 03:32 PM
cl440's Avatar
Thanks mywifesquad. I sent an email to Kazuma but I doubt I will get a response.
Old Oct 19, 2005 | 03:36 PM
KTM Patrol
Former Chinese POW!
I talked to a bunch of people involced with the chinese 110's and 150's. Not one person could even begin to help me. A few tried but said their manufacturers had no answer either. The 150's valves were too tight(exhuast) and loose(intake) and it didnt have 3 hrs on it when i checked.
Old Oct 20, 2005 | 08:24 AM
cl440's Avatar
Well I was shocked to find this response in my email this morning!
For Meerkat50-4A, Panda100-4SA, Cougar250-4M
Dear Chuck:
1. Please see attached the specification of engine valve clearance. Do not
try to adjust yourself if you are not a skill mechanic, because it will
damage the engine valve and lose the engine pressure and you will not start
the bike.
2. You can contact us for any tech. information you need, but we don't have
printed manual.
3. Please go to Safety Recall, and click " Safety
causing......", you have to rivet a pin into the A arm.
Kazuma Support Division
Adjusting Valves:
1. For TDC Mark
Looking from the right hand side of the engine casing, the magnet on the crankshaft ,which form
part of the genaretor has mark on it.the arrow on the magnet must face the mark on the casing,
thats is TDC ( piston top )
2. When the piston is TDC , that's ignition timing.
Looking at the camshaft from the front of the engine the following will be seen
( a ) A slot in line with the big hole of the cam gear .
( b ) The two small holes of the cam gear will be flush with the turpet cover seat on the head, the
cam lobes are free.
3. The valves clearance
( a ) The inlet valve 0.05 mm
( b ) The Exhaust valve 0.05 mm
Less than 24hr. response time? Are they really going to give this customer service thing a try? Maybe I just got lucky?
Old Oct 20, 2005 | 08:58 AM
KTM Patrol
Former Chinese POW!
That is great cl440, maybe some of them are trying to turn it around.(lack of customer service that is) And its also nice to have my .002 number confirmed. Thanks again, MWQ
Timdaddyo4
Ask the Editor
Apr 27, 2024 06:50 AM
donintennessee
Jan 8, 2021 12:40 PM
Hankey Pankey
May 1, 2018 01:33 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
rjacree
1) Engine problems..
Aug 3, 2015 10:21 AM
