moron needs help removing castle nut
Old Oct 20, 2005 | 10:47 PM
wrestleu's Avatar
Default moron needs help removing castle nut
Yes I'm a moron....I"ve been trying to get the castle nut (rear axle) off my 185S to no avail. I've tried an impact...monster breaker bars etc. Short from taking a chisel to it....how the heck do these things come off? And yes...I have removed the cotter pin. I see a good amount of loctite on the axle spindle...so I'm assuming the last person didn't anticipate the brake/bearing woes I am having when he reassembled it last. Which for all I know could have been over 20 years ago.
Old Oct 20, 2005 | 10:57 PM
Sparky8370's Avatar
Put it in gear, apply e-brake. Use a breaker bar and a pipe that will fit over it, like a lolly column, so you have an extension a few feet long. Should come right off if you pull down fast and hard on the pipe. You may need to strap your quad down on a trailor, or otherwise immobilize. Hey I didn't mean to rhyme, or use hard and on in same sentance.
Old Oct 21, 2005 | 02:34 AM
ThrashAndCrash's Avatar
STOP!!!!!!!!!!!!!!!!!!!!....before you put a bar on it with it in gear........If there is loctite... HEAT the nut with a small propane torch, then use your impact. .......it will come off!!!!!!! Loctite is made to breakdown with heat.
Old Oct 21, 2005 | 03:04 AM
JkAss's Avatar
Amen brother, use the torch first before using a breaker/torquemultiplier bar on the nut. YOu will do some serious damage to the nut and the threads of the axel.
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
clscott84
Sep 21, 2015 10:16 AM
Canamaniac!
Sep 15, 2015 06:19 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
