scram 400 wheelie
Old Oct 21, 2005 | 12:14 AM
RealAce's Avatar
Default scram 400 wheelie
does ne body else that has a scrambler 400 find it hard to ride a wheelie on it my friend has a 500 and can do them on there but they have the HO for low end and 2 strokes are mainly top end just wondering bc im like 135lbs so
Old Oct 21, 2005 | 12:34 AM
scrammersam's Avatar
i find it hard to but mine is 4x4 and i dont have any clutching done
Old Oct 21, 2005 | 01:00 AM
400crasher's Avatar
Its easy for me. I grab the brake and pin the throttle, then let go of the brake and pull back. It pops right up!
Old Oct 21, 2005 | 07:51 AM
ftwflh's Avatar
My last 400 Scrammy all you had to do was hit the gas and hang on and let off before it came all the way over.A clutch kit really helps.
Old Oct 21, 2005 | 10:37 AM
Hoopie's Avatar
My all stock srambler 400 will not come up even with me pulling on the bars and sitting on the back. I have to stand on the grab bar. Im sure clutch work and pipe would fix that. Stock it doesnt have enough low end power.
Old Oct 21, 2005 | 10:44 AM
duneaholic's Avatar
I could wheelie my stock 400. There's a little timing to it. When you gas it don't just pull back right then. Wait for the powerband to hit then pull. It will come up I assure you. Just be ready to hit the brake cause when they come up they come up fast.
Old Oct 21, 2005 | 10:55 AM
chris15706's Avatar
What are you guys sitting on the gas tank and trying to wheelie? If i can wheelie on my 250 trail boss yall should have no problem with a 400.
Old Oct 21, 2005 | 11:05 AM
conig's Avatar
if your having problems with a stock 400 it may be time for a rebuild, there should be more then enough power to lift them up. I know this isn;t a possitive response but I would definatly say check it out.
the timing is definatly difficult, pre pipe I could ride one out for a good 25 yards. the balance point is hard to find and the clutch doesn;t seem to want to keep the wheels up when you have to let off the gas and then gun it again to ride one out. I'm a light guy as well no more then 30 pounds over 135 pounds.
Old Oct 21, 2005 | 11:21 AM
CED's Avatar
CED
No problem here.[img]i/expressions/face-icon-small-happy.gif[/img]
Old Oct 21, 2005 | 12:31 PM
XtremeSkier's Avatar
yeah i agree w/the timing...
i may have a 4 stroke but i had to do alittle bit of timing at first...now i just know because i've done so many wheelies and i know when i need to pull up
