01 Rubicon valve clatter
Old Oct 21, 2005 | 11:03 PM
Lenox273's Avatar
Default 01 Rubicon valve clatter
My 01 Rubicon has a slight valve clatter cold and hot. It is just enough that you would think it is time to check the adjustment. I did that today and have a few questions. I do not have a repair manual and the owners manual does not state if the clearance is checked cold or hot. I checked it cold and could not get a .006 feeler guage under either one. Spec is .006 int and .009 exhaust. Is there something I don't know? clearance usually gets tighter hot. Is ther an alternate spec most others use? Noise is not bad just thought I should check it. Only has 350 miles and has never been set before. Thank you. I have another question that I am going to post spearately about the newer Rubicon bodies fiting the older style Rubicons.
Old Nov 7, 2005 | 12:49 PM
bgblk502's Avatar
book said to check cold
Old Nov 7, 2005 | 07:08 PM
Buckets's Avatar
had the same concern on my forman, tried everything, then noticed in my repair manual it gave the spec for the valve spring tension, had them checked and they were weaker than the spec chagne them, noise gone. If you have yours apart it would would be worth checking your valves for sticking and your valve spring. Nothing to lose.
Old Nov 7, 2005 | 07:09 PM
Buckets's Avatar
sorry, not the valve spring tension but the valve spring height minimum.
Old Nov 16, 2005 | 04:16 AM
rubiconrider101's Avatar
yea make sure and check the valves stone cold, and be sure and get em set right, it makes alot of difference in starting and running, mine came adjusted wrong from the factory.
Scooter's Shop
23
Oct 22, 2015 07:04 PM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
