01 Raptor jerks forward after shift in to 1st
I don't know if this is normal. My Raptor will lunge forward when shifting from neutral to 1st. Similar to an old automatic car when shifting into D. Any ideas?
Is it only the first time each day. Once its fully warmed up, does it still do that?
Its pretty normal for a wet clutch to behave this way, the oil is cold and thicker, and theres still drag on the clutch plates even with the clutch lever pulled in. But once the motor is hot, it shouldnt do it. Check the adjustment of the cable, if it does it all the time.
yeah my dirtbike does that I thought my clutch was going but my engine guy said it was just the plates sticking. When i Start my dirtbike up for the first time of the day with the clutch all the way in when i drop into first it bucks a bit or stalls if i dont have enough throttle then doesnt do it again. I dont know if theres somthing you can do to "fix" it but i was told its not damaging so i didnt mess with it
It does it all the time, harder when cold. I tried jacking the rear and running it in 1st with the clutch disengaged to see if the clutch is dragging. No drag.
MeadowlarkFarm
Nov 27, 2019 08:40 PM
