Hub fluid leaking...
Old Oct 28, 2000 | 10:21 PM
Xplor's Avatar
I noticed after a hard ride that there was oil on my left front disk. The next day it had leaked as far as to fill the lower lip inside the rim of the tire. At first I thought it was brake fluid coming out of the galipers/piston but it looked more like Hub fluid.
Could this come from a broken seal? Is it hard to fix? I rode with it today because I could not keep myself off the Scrambler... It seemed fine. I still would like to change the seal though...If that's what it is.
Any ideas?? Thanks
Old Oct 29, 2000 | 01:48 PM
jrossow's Avatar
Yep, you have a classic case of a bad hub seal. Personally, I don't find it hard to replace the hub seal. You have to take the hub and brake disc off to get the seal out and replace it. The seal is about a $12 part if I remember right. Just remember to clean your brake disc and brake pads with brake cleaner. And don't drive it without hub oil!
Old Oct 29, 2000 | 02:11 PM
Xplor's Avatar
Thanks for the input jrssow!
I checked it again today and it did not loose any fluid during my ride yesterday. It was a bit "mucky" looking so I changed it again. I will have one more ride on it then change the seal this week.
Side question: Theoretically, if I leave it in 2x4 mode and have no hub fluid...will it still screw things up?
Thanks
Old Oct 29, 2000 | 02:37 PM
ChopperBill's Avatar
Make sure that the wear sleeve does not have a groove in it or you will probably have to do it over.
Old Oct 29, 2000 | 02:53 PM
jrossow's Avatar
There are four tapered wheel bearings in the hub that are lubricated by the hub oil. So, even in 2x4, there are still parts in the hub that need lubrication. Actually, the only part of the 4x4 system that requires lubrication is the hilliard clutch and that is only when the the front wheels engage and disengage.
Old Oct 30, 2000 | 12:38 PM
wolp's Avatar
I have a leaking hub on my 99 Scrambler 400. I have the replacement seal. On one side of the seal there is a spring that goes all the way around the seal. Does this spring side face inside or outside of the hub?
Old Oct 30, 2000 | 01:35 PM
sp500's Avatar
I have a 2000 polaris 500 and i had to replace the front hub seal. I have the manual and followed the steps it was pretty easy. My only problem was the dealership gave me the wrong seal. After that it was very easy.
Old Oct 30, 2000 | 08:45 PM
Xplor's Avatar
I might have a lucky streak guys. I brought the Scram to the dealer and they will try to put all the problems on warrenty work! I forgot the quad is only a bit under 6 months old! Seals, chain, bearings, lower steering bushing, brakes!
I hope they all get done under warrenty...
Brian
Old Oct 30, 2000 | 09:38 PM
floodrunner's Avatar
If you have a leaking hub seal at under 6 months and you have a decent dealer it will be covered under warranty, as it should. Of the 8 Polaris quads I’ve owned, five have had hub seal leakage, some more than once.
MaasaiMomma
Mar 25, 2021 11:24 AM
hueby
Nov 6, 2015 11:34 AM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
Technical and How-To Articles
Aug 21, 2015 09:31 AM
rcappie4
Jul 10, 2015 04:54 PM
