1999 Wolverine Smoking
Old Oct 27, 2005 | 10:21 PM
OverTheEdge's Avatar
Default 1999 Wolverine Smoking
I own a 1999 Yamaha Wolverine that's been giving me problems pretty much since I bought it last summer. The main problem is that it smokes when I first start it up after it's been sitting for a while. It's been rebuilt twice now(it used to burn oil while running thanks to a pitted cylinder courtesy of the previous owner), and I had the valve seals replaced twice as well. It doesn't seem to burn oil while it's running now, but when it does smoke while starting it, there's enough blue smoke to fill the garage up. It doesn't stop smoking either until a few minutes after I've been riding, then it seems to clear up. Sometimes it blows out huge amounts of smoke at startup, and other times there's barely any smoke at all.
Can someone please give me a list of possibilities as to why this is happening? Could it be the valve guides letting oil leak down into the cylinder? Has this happened to anyone else?
Thanks in advance for any help or tips to fix this problem.
Old Oct 28, 2005 | 12:56 AM
ZillaRider02's Avatar
You can rule out the piston rings as the culprit if it stops smoking when warm. If no oil is being drawn into the cylinder from a crankcase vent or through the airbox, the problem is most definately the valve guides and or seals.
Old Oct 29, 2005 | 01:34 AM
86250rrider's Avatar
like he said above. the rings will smoke after warm upon deceleration(no load). if you have problems with seals over and over i would suggest getting a valve job. new valves (2) , springs,keepers,and a decent machinest to fit them togethjer with the new seals. or do what i did with the lt230s i had , ignore it until the next rebuild!![img]i/expressions/face-icon-small-happy.gif[/img]
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
EIF
Apr 20, 2017 07:15 PM
rockinkgin
Sep 25, 2015 01:52 PM
Steeldon
Sep 9, 2015 09:38 AM
